Thread: Traction control question
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    Default Traction control question
    We are trying to use a 2014 Silverado for snow work (snow plow, and recovery work) but the traction control keeps kicking in. we turn it off on the dash,but as soon as you hit 25 mph of wheel spin it kicks back in automatically. which renders us useless in a lot of situations. is there a setting to shut this down permanently? or open it up to higher speeds?
    Aug 2016
    Can you press and hold the traction control button for 30 seconds to disable traction control and Stabilitrak?
    Sent from my Pixel 3 using Tapatalk
    Jun 2010
    Quote Originally Posted by pinstripebob View Post
    Yes I know, but as I said at 25 to 35 mph wheels slipping it re-engages automatically. That is our problem.
    Dec 2016
    There should be many things you can change for the traction control. Post your calibration file if you need help. Easiest is the temp enable and just max that out.
    Aug 2016
    Not everyone knows there's a difference between a quick press of the traction control button and a 30 second press and hold.
    I found a 2014 Sierra 6.2L stock tune and a T43 transmission tune, I didn't see much for traction control. As In-Tech said, posting your calibration will help others diagnose your issue.
    Thanks for that info.
  1. Traction Control
    By SV8346 in forum E98 2014+ Diesel ECM
    Last Post: July 25th, 2017, 10:47 PM
  2. ABS, Traction control, Cruise control..
    By GMCAMARO in forum Gen III V8 Specific
    Last Post: January 23rd, 2016, 02:10 PM
  3. traction control off
    By jeff keyuk in forum Gen III V8 Specific
    Last Post: February 14th, 2010, 04:11 AM
  4. traction control
    By 69camaro5speed in forum E37, E38 & E67 PFI ECM's
    Last Post: September 29th, 2007, 02:11 AM
  5. Traction Control Switch question
    By Beer99C5 in forum Lounge
    Last Post: July 26th, 2007, 02:36 AM
