Thread: Seeking Base Tune - 03Z with LS2 402 / V3Ti
    Jun 2019
    Default Seeking Base Tune - 03Z with LS2 402 / V3Ti
    My LS6 ate a lifter and cracked the block, so I had an LS2 402 built which I am picking up this weekend.
    This is a 58x build, so I believe I will need to use the LPE signal conversion box for cam and crank position sensors. I'll be mounting the knock sensors (LS1 style) to the block exterior.
    It's a simple street build.
    402 @ ~10.5:1
    Arun Jam Cam
    LS7 TB w/ harness adapter
    FAST 92
    (not sure which MAP sensor is on this car currently)
    Siemens Deka #60 injectors
    no MAF
    and a V3Ti w/ 3.8" pulley for now
    Any help getting it started would be appreciated.
    Will your engine builder tune your PCM...? He will run the engine on his dyno, get him to run your PCM (and the LPE CKP/CMP converter).
    Jun 2019
    No, he is a pro machinist who has been building race engines for years for various track sports. I have a few tuners near me of great experience for dialing it in tightly. For now, a functional idle will suffice. In the long run I don't know if I will stick to factory ecu or one of the aftermarket units.
    Jul 2003
    TRG for the win... works rather well.
    Jun 2019
    Trg?
    Jun 2019
    Figured it out after, lol.
    Any suggestions on places to look for an approximate base tune to get the car to idle?
  1. Replies: 2
    Last Post: June 7th, 2019, 12:13 PM
  2. Tuning an LS2 for my 69 Camaro - Base Tune?
    By Taylor1969 in forum General
    Last Post: April 21st, 2011, 02:42 AM
  3. base tune 402
    By theoz385 in forum Gen III V8 Specific
    Last Post: February 23rd, 2010, 02:01 PM
  4. LS1 to LS2 Base Tune Please
    By hrc2007 in forum Gen III V8 Specific
    Last Post: January 15th, 2010, 04:12 AM
  5. LS2 402 lean idle
    By white2000ta in forum General (Petrol, Gas, Ethanol)
    Last Post: April 3rd, 2006, 03:59 AM
