Results 1 to 8 of 8
Thread: Flash failed, door was ajar, alarm sounding constantly
    Feb 2007
    Default Flash failed, door was ajar, alarm sounding constantly
    Hopefully I can recover from this, door was ajar and the wind was blowing during cal flash, flash failed, turn off the ignition and alarm and hazards flashing, had to disconnect the battery, alarm restarts as soon as battery is reconnected, is there a solution for this?
    Feb 2007
    Fortunately I remember I have a bench harness, just never used it before, ill try disconnect PCM from the vehicle and reflash
    Feb 2007
    do I need disconnect the centre plug while the bench harness is connected during bench flash?
    Feb 2007
    Bench flash went ok, PCM status is ok, but alarm still active when battery reconnected, any ideas ?
    Feb 2007
    Too late at night now, I’ll try connect the battery again in the morning and use the key fob too lock and open the car
    Well you never mentioned what vehicle type or controller you were dealing with, makes it hard to offer advice.
    Feb 2007
    Sorry about that, its an E40 on a HSV Monaro. The alarm disarmed with the key fob, I had Deja vu, im sure I had same issue a few years back.
    I don't remember any specifics either aside from I know the anti-theft alarms in the HSV's were problematic at the best of times.
  1. FAILED RE-FLASH p10
    By tblu92 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: December 23rd, 2010, 10:44 AM
  2. failed flash
    By pdasterly in forum FlashScan V2
    Last Post: January 6th, 2010, 05:21 PM
  3. failed flash
    By 69camaro5speed in forum Allison 5 & 6 Speed
    Last Post: January 8th, 2009, 01:58 PM
  4. Reading PCM with Z06 Door Ajar :S Check Engine
    Last Post: March 24th, 2005, 08:05 AM
