Results 1 to 2 of 2
Thread: complete noob needs help opening a .tun file
    Member jeeper's Avatar
    Oct 2018
    Default complete noob needs help opening a .tun file
    I'm a complete noob and need some help.
    I'm trying to swap a Vortec 5.3 from a 1999 Silverado into a Jeep TJ. I got a complete donor truck and removed the engine, computer and all wiring to go with it. I have it all bolted into the TJ frame and tried to start it but have no spark.
    After doing a bunch of reading I came to believe I needed to create a custom OS to eliminate the automatic transmission from my current os which is 09373372. So I headed over to a site that is linked in another post about moving tables from one tune to another. (If needed I can provide the link.) I found a 1999 Camaro manual trans that uses the same OS so I downloaded it. My problem is it won't open with either v7.5 or 8.
    I then read some more and user Taz suggested in another thread that 12212156 from a 2002 Camaro manual trans may be a good OS for the OP of that thread so I thought I'd try downloading that one to take a look at it. Turns out I can't open that one either.
    To add some missing details, I did disable VATS on the LS1B computer from the Silverado. Also I am not using the GM computer to activate the starter relay. I am using the Jeep computer and wiring to crank the starter over. I am keeping the Jeep computer to be able to use the stock Jeep gauge cluster for now. I have installed additional coolant temp and oil pressure sending units on the engine.
    I'm probably missing something pretty basic but my problem is I don't know what it is that I don't know. If anyone can point me in the right direction I'd be grateful.
    2002 Duramax
    project Jeep Wrangler to CJ conversion with a LS engine and 6L80e transmission underway
    Oct 2018
    Please delete this thread. It is a duplicate. I didn't realize there was a message indicating my post needed to be approved by a moderator before if goes live so I made another thinking I did something wrong when creating a new thread.
    2002 Duramax
  1. problem opening tuning file
    By jmstekguy in forum FlashScan V2
    Last Post: May 27th, 2013, 01:33 PM
  2. Diable auto opening of last file used?
    By SwedeBurb in forum General
    Last Post: May 25th, 2012, 05:37 PM
  3. Opening a log file?
    By jfpilla in forum General
    Last Post: June 27th, 2007, 01:24 PM
