Results 1 to 3 of 3
Thread: VE Series 2 - E39 VATS relink / relearn
    Oct 2019
    Default VE Series 2 - E39 VATS relink / relearn
    I was wondering if anyone can help me out with the process to relink the ECM and BCM in a VE series 2?
    This VE originally had the E69 ECM and the engine has been swapped including the ECM to E39.
    I have disabled VATS in the E39 and the engine runs, but i get the warning on the dash for "Engine Immobilised"
    I updated the VIN in ECM and TCM with the Scan 7.5 software but when looking at the Tune 7.5 software for VATS relink / relearn, Tune 7.5 doesn't list E39 ECM...
    I also flashed the ECM with VATS relearn after X seconds, was set to 0, tried 30 seconds. Tried the ignition on for 30, off, on, off, on etc - no luck.
    Hopefully it is something easy i am missing and i didn't waste money on license!
    Quote Originally Posted by luke1 View Post
    I'm not sure that the theft systems are compatible between those generations of vehicles.
    Well the engine runs so it's not really a waste of money.
    As I said I don't know if the older BCM will marry up with an E39 with the VATS CAN messages, I don't know enough about it.
    But to continue to try to link them you'll need to full flash a stock file back in (eg, VATS still enabled). The learn process probably won't work with the VATS patched out.
    Oct 2019
    I tried replying to this earlier, where did my post go?
    The E39 ECM is available in the same year VE as mine 2010 with 3.0L engine. Mine had LLT 3.6L with E69, and i swapped with LFX 3.6L with E39. Even though i can get engine running with VATS disabled, with "Engine Immobilised" on the dash and DTCs it wont get roadworthy or registration!
    The full flash of the original tune didn't help. I tried the power on, off process a few times with no luck.
    I also tried with the VATS relearn after "30" seconds, instead of the "0" default. Same, no luck.
    It seems I really need to use the Tune 7.5 Security VATS relearn feature, but Tune 7.5 doesnt have the E39 ECM as a selection...
  1. VATS relearn help please.
    By Daws222ooo in forum General
    Last Post: December 31st, 2014, 11:29 AM
  2. E78 VATS Relearn
    By SkyMadness in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 13th, 2014, 09:55 PM
  3. VATS relink with scan only?
    By mr.prick in forum FlashScan V1
    Last Post: July 9th, 2009, 11:58 AM
  4. How do I perform VATs to BCM Relink?
    By KAZ MotorSports in forum Gen III V8 Specific
    Last Post: May 12th, 2008, 12:41 AM
