Results 1 to 7 of 7
Thread: C0558 hard code after reflashing for a gear change
    Jan 2009
    Default C0558 hard code after reflashing for a gear change
    So I went and changed the gears in my 2005 Yukon yesterday from 3.73 to 4.56 gears and after making the initial calibration change for the gear ratio, I got a hard C0558 code which is "calibration Data Not Programmed/Learned". I have tried to put the original cal back in to see if that would revert it back but no go. Any ideas of what happened when I flashed the ECU? I have not had this code at all before flashing it yesterday.
    Aug 2016
    Do you have separate engine and transmission tunes, and if so did you make the change in both of them? Can you post your tune files?
    Sent from my Pixel 3 using Tapatalk
    Jan 2009
    It's a LS1b ecu so both the engine and trans cals are within the same ECU and are not separate.
    C code is from either body/chassis controller or ABS controller...
    Jan 2009
    I saw the code description when I pulled the code. I was just trying to figure out how the ABS module lost it's cal info after I changed the gear ratio in the ECU.
    It didn't it must know there is now a mismatch between the ECM and ABS.
    Jan 2009
    I tried to put back the original call and the code is always there though. With that, I have to guess that the ABSinfo got erased with the reflash.
  1. C0558 fault code in 2007 silverado
    By nigor in forum General
    Last Post: October 9th, 2018, 04:52 AM
  2. 2005 c6 vette how to change gear ratios in file after gear swap
    By AllOutPerformance in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 21st, 2016, 08:48 AM
  3. C0558 Trouble Code: "Calibration Data Not Programmed"
    By dc_justin in forum General (Petrol, Gas, Ethanol)
    Last Post: February 29th, 2012, 09:54 AM
  4. LBZ gear change
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 28th, 2008, 01:25 PM
  5. quick gear change question
    Last Post: August 9th, 2006, 08:24 AM
