Results 1 to 2 of 2
Thread: Holley 3 Bar MAP scaling?
    Jun 2008
    Default Holley 3 Bar MAP scaling?
    Anyone have the MAP Sensor Scaler/Offset settings for the Holley 554-107 3 Bar MAP?
    -John
    1991 RCSB 2WD Sierra LQ4 swap, 220/224 112 cam, Twin VSR 6766 turbos
    4L80e w/shift kit, PY 3600, and 3.73 gears.
    22 PSI and E85, 4300# with driver. 9.7@138, 1.47 sixty
    :drivin:
    That looks like the old design MAP sensor from the 80's or 90's. Not sure of the scaling on one compared to the new design sensors. If you can't get it worked out with manual testing Holley does offer an adapter.
    HOLLEY EFI LS MAIN HARNESS TO LS3-STYLE MAP SENSOR ADAPTER
    Adapter Harness
    PART# 558-416
  1. Updating 2 bar to 3 bar map sensor
    By badls1 in forum Gen III V8 Specific
    Last Post: November 2nd, 2015, 11:40 AM
  2. scaling 2.5 bar MAP sensor in an E92
    By 9secVette in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 22nd, 2015, 02:38 AM
  3. COS 3.3 bar map only reading 2.5 bar
    By BAD BOB in forum FlashScan V2
    Last Post: August 8th, 2011, 11:27 AM
  4. 3 Bar MAP sensor doesn't work with 3 Bar scaling!
    Last Post: April 27th, 2010, 04:21 PM
  5. MAP Scaling Help
    By lplott in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 7th, 2006, 06:45 AM
