Results 1 to 4 of 4
Thread: LSX454 E67 checksums disabled
    Default LSX454 E67 checksums disabled
    I am trying to tune this LSX454 crate engine with the supplied E67 and harness. I was able to read the file with no issues, but it says Checksums Disabled and will not let me flash.
    Thanks for the help in advanceGeneGrimesLSX454_0000.ctz
    This is normal for those GMPP files.
    You simply correct the checksums, if you are looking in V7 there is a button just above where the checksums are shown called "Update Checksums", click that and resave your file.
    That's what I did just making sure before I tried to flash it. Thanks
    Good decision to check, when they are marked as disabled it is usually ok to correct them, if they ever show as incorrect (with a red marker) then that would indicate there is probably something wrong with the file and it should not be used.
  1. Checksums
    By twildman in forum Cummins 5.9L
    Last Post: January 28th, 2021, 02:27 AM
  2. LSX454 w GMPP E67 ECM - Idle Surge
    By LastCall in forum E37, E38 & E67 PFI ECM's
    Last Post: November 24th, 2017, 02:19 AM
  3. Tune file for a lsx454
    By stick100 in forum Gen IV V8 Specific
    Last Post: October 27th, 2013, 11:18 PM
  4. Replies: 9
    Last Post: September 30th, 2011, 03:23 PM
  5. one or more incorrect segment checksums?
    Last Post: April 20th, 2005, 02:33 AM
