Results 1 to 7 of 7
Thread: Cant flash controller I have had licensed for years? LS1B
    Junior Member jderekt's Avatar
    Mar 2017
    Default Cant flash controller I have had licensed for years? LS1B
    Need help, LS1B controller I have had licensed for years now suddenly wont let me flash to it due to no license?
    I used the controller to show a buddy how to program a pcm using my Tech II in pass-through mode and unintentionally did flash the pcm due to me not paying full attention. This changed the OS and VIN, so I took out my V2 and reloaded my OS and tune file via a full flash in V8. Now it will not let me flash at all saying I need to buy a license?? HELP! I have more work to do to this file!
    Th controller serial number is not changeable is it??
    I did run an update on V7.5 after the full flash in V8.
    TIA,
    Derek
    1998 S10 ZR2 Ext Cab.
    4.3L Vortec
    4L60E Auto trans
    0411 PCM and Engine/trans harness
    .020 over bore
    Comp 266HR cam
    Comp roller tip rockers
    Volant cold Air Intake
    Mercury Marine intake manifold
    JBA stainless shorty headers
    Borla full exhaust with high flow cat
    TechII will happily wipe out / corrupt serial numbers of controllers (LB7 Duramax's suffer this with Tech-II as well), but the S/N is not something EFILive will or can change.
    It's not normally something that happens with the LS1 PCM though, when you go to the OBD-II tab in V8 and get info does it actually return what looks like a valid S/N or is it rubbish (eg, not letters and numbers)?
    Mar 2017
    Perfectly valid appearing data.Click image for larger version.
    4.3L Vortec
    4L60E Auto trans
    .020 over bore
    Comp 266HR cam
    Mar 2017
    I was able to do a VIN change through V7.5 scan tool, but when I tried to flash a calibration I get this:
    4.3L Vortec
    4L60E Auto trans
    .020 over bore
    Comp 266HR cam
    Mar 2017
    Was able to do another full flash using V7.5. PCM is pretty screwed up now, will not take a crank relearn and my Edge CTS2 monitor is not showing any PID's in the list when I try to change them. Is there a good way to just dump/recover this PCM and start over?
    I have a spare PCM with a file on it. Looks like I will just have to spend the money on a license for it and start over.
    4.3L Vortec
    4L60E Auto trans
    .020 over bore
    Comp 266HR cam
    In V8 software, goto the VIN Licenses page, see if shows your PCM's serial number as you see it in your pic above.
    Mar 2017
    Did that. Was not there. I'm sure the stupid tech II changed it. I'm pretty much a rookie to the flashing/tuning world and likely partly to blame.
    I got a fresh factory file loaded and just paid for another license.
    Sent from my SM-G975U using Tapatalk
    4.3L Vortec
    4L60E Auto trans
    .020 over bore
    Comp 266HR cam
  1. Strange advance behavior - 2006 Silverado 5.3 LS1B controller
    By trimchip in forum Gen III V8 Specific
    Last Post: April 28th, 2015, 06:53 PM
  2. licensed controller says it not??
    By 6772king in forum Duramax LB7
    Last Post: August 22nd, 2013, 01:32 PM
  3. Cannot flash Licensed PCM?
    By Lextech in forum Gen III V8 Specific
    Last Post: March 6th, 2013, 03:30 AM
  4. Replies: 4
    Last Post: January 3rd, 2013, 08:15 PM
  5. Replies: 4
    Last Post: September 10th, 2010, 01:38 PM
