Results 1 to 1 of 1
Thread: Auto Cal USB communication problem $0024
    Nov 2019
    Default Auto Cal USB communication problem $0024
    Hi,
    I have had my autocal a couple years and only used it a handful of times. It has always worked perfect. It still works perfect hooked up to truck but I have a USB problem.
    I have tried 3 different cables and 4 different computers.
    Windows says Device isn't responding when its plugged in. EFI_Hapi goes crazy if I try to launch it directly from Program files folder. I get Access violation over and over and over.
    If I launch EFI scan and tune it will give and error and close. Attached are the 2 screenshots of the different scenarios.
    I'm getting ready to swap motor and transmission and desperately need this working please help.
    Firmware Version: 2.07.113
    BootBlk: 2.07.007
ID:	23095Click image for larger version.
ID:	23092Click image for larger version.
  1. USB connection problem, no solder on pins?
    By board350 in forum FlashScan V2
    Last Post: May 15th, 2013, 03:36 PM
  2. GMH V6 communication problem
    By davewanna in forum EFILive V4
    Last Post: April 11th, 2013, 09:58 AM
  3. Replies: 6
    Last Post: March 26th, 2011, 04:58 PM
  4. usb driver problem! please help
    By byler900f in forum FlashScan V2
    Last Post: May 30th, 2009, 11:22 AM
  5. EFI Live V2/USB Comunication Problem
    By castewart in forum Duramax LB7
    Last Post: May 21st, 2009, 09:55 AM
