Can you turn off check engine codes in Cummins hd like you can in the non hd tuner?
No you can't and the non HD tuner does not support code removal either.
Is that something they started recently? In v7.5 they had dtc enable list.
Only about 9 years ago
Certainly for Cummins no Dodge from 2010 up has ever had DTC disable options.
It was a duramax that the program was being used on I thought it was the same for all. Thanks for the info. Now I know
