Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: need B9021 for 01250003
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Default need B9021 for 01250003
    Is there a .cax available to give me table B9021 for 01250003? Thanks!
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    Aug 2006
    I have looked through all of my stuff. I don't have one---That doesn't mean one doesn't exist. What year OS is that one based off of?
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Jun 2005
    Thanks for looking! It is based on a 2001 OS...
    GM EFI Tuner
    Sep 2003
    Default CAX File
    I had this cax file, but I don't know what is in it.
    The only cax files I have for B9021 are for 12212156 and 12202088...
    B9021 has not been yet reverse-engineered inother files yet.
    Jun 2005
    Just out of curiosity, I took one of those and renamed it 01250003 - you can then see B9021 - is that not a good thing to do? I just did it on my home laptop to see what would happen, not on my tuning laptop...
    GM EFI Tuner
    Jun 2005
    Quote Originally Posted by Ninety8C5 View Post
    Not B9021...
    GM EFI Tuner
    Oct 2006
    Here you go.
    The Tremor at AIR
    Quote Originally Posted by BLK02WS6 View Post
    No, some of those tables are at different addresses causing all tables after those to be shifted also.
    Jun 2005
    Quote Originally Posted by 5.7ute View Post
    Here you go.
    Thanks!
    GM EFI Tuner
  1. is B9021 available for OS 12587603?
    Last Post: November 4th, 2011, 03:39 AM
  2. b9021
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 12:22 PM
  3. {B3647} in 01250003
    By SS2win in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2005, 02:32 PM
