Results 1 to 3 of 3
Thread: Crank relearn help?
    May 2019
    Default Crank relearn help?
    I am doing a custom install into an earlier car and as I get closer to starting this thing, I have been browsing the forum. I am coming up with questions, but answers are elusive. Could someone please tell me what the conditions are that need to be met to get the silly thing to do a crank relearn? I am installing a neutral safety switch on the 4L60E so that I can get the correct inputs to the ECU. I will be running a brake input, and I haven't found the park brake input yet??? Any one know the correct pin to run to the park brake ground?
    thank you and stay safe
    May 2019
    Thank you
  1. crank relearn??
    By 2004gmc in forum Lounge
    Last Post: July 30th, 2021, 12:24 PM
  2. Crank Relearn
    By dhjernigan in forum FlashScan V2
    Last Post: November 7th, 2011, 10:12 AM
  3. Crank Relearn
    By JimmyJazz in forum FlashScan V2
    Last Post: May 3rd, 2011, 10:37 PM
  4. crank relearn
    Last Post: August 28th, 2008, 06:07 AM
  5. Crank Relearn
    By mk6racer in forum Gen III V8 Specific
    Last Post: May 15th, 2008, 11:05 AM
