Hey guys, similar but opposite problem as the other thread but totally different setup.
Cam/Ported stock heads/Shorty headers 00 Camaro
It seems like we got the MAF sensor tuned in and it runs pretty well on that. We are now trying to dial in the VE table and are having trouble.
1. I added like 20% to the VE table in WOT conditions and didn't really pick up any AFR. It seemed to be effecting cruise a little when I modified the map in that area. Didn't seem to have DTC related to MAF either although I tried to disable it.
2. The % error calculation in the calc_pids file isn't correct. AFR seems to work. Why does it seem like this thing can't do math with negative numbers in that file?
Attached are the tunes, files and logs. I read through all the stickies and stuff several times but I seem to have problems that I'm not supposed to
