Results 1 to 7 of 7
Thread: LS1B VE Tuning No Effect
    Nov 2018
    Default LS1B VE Tuning No Effect
    Hey guys, similar but opposite problem as the other thread but totally different setup.
    Cam/Ported stock heads/Shorty headers 00 Camaro
    It seems like we got the MAF sensor tuned in and it runs pretty well on that. We are now trying to dial in the VE table and are having trouble.
    1. I added like 20% to the VE table in WOT conditions and didn't really pick up any AFR. It seemed to be effecting cruise a little when I modified the map in that area. Didn't seem to have DTC related to MAF either although I tried to disable it.
    2. The % error calculation in the calc_pids file isn't correct. AFR seems to work. Why does it seem like this thing can't do math with negative numbers in that file?
    Attached are the tunes, files and logs. I read through all the stickies and stuff several times but I seem to have problems that I'm not supposed to
    Lifetime Member Gregs's Avatar
    Sep 2008
    I see you have 0Hz for the MAF fail. Have you tried 1Hz instead? Is the MAF unplugged? Are you getting a MIL for the MAF being failed? You should be getting a check engine light if the MAF is being failed correctly since you have the MIL enablers set to report the code.
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Nov 2018
    I actually had that idea. No, I don't believe I'm getting a code (Flashscan pulls nothing). No, I didn't unplug it. I was assuming the IAT was coming from it also?
    I'll set it to 1 and try. Thanks
    Oct 2011
    change C2904/5 to 20000
    change c2903/6 to 1
    unplug the maf and try again, your not in speed density it sounds like, it should throw a MAF code instantly
    Important: are you seeing a MAF DTC...?
    Also:
    what are you doing with "(({CALC.AEM_AFR}-{GM.AFR})/{GM.AFR})*100", how are you adding that much percent to the VE table...?
    If you use "{CALC.AEM_AFR}/{GM.AFR}" you can paste-multiply this value directly into the VE table.
    Which stickies did you read thru...?
  1. Spark IAT table and it's effect on spark tuning.
    By Illegal Vette in forum Gen III V8 Specific
    Last Post: May 30th, 2017, 05:35 PM
  2. 2 Quick Questions: LS1B Tuning
    By truethinker in forum Petrol / Gas
    Last Post: August 19th, 2015, 10:50 AM
  3. LS1B Black Box Tuning?
    By Wolfie in forum Gen III V8 Specific
    Last Post: May 8th, 2012, 05:00 AM
  4. Ported TB effect on VE?
    Last Post: April 22nd, 2008, 01:02 AM
  5. Tuning VE with RR...no effect
    By Wichita Dyno in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 6th, 2007, 04:18 AM
