Results 21 to 30 of 48
Thread: AEM 03-0334 wideband BEN
  1. #21
    Member ToonerSQUAD89's Avatar
    Dec 2018
    i chose that PID as well from the selected amount tho
  2. #22
    Dec 2018
    I choose W02S11, and the drop down EQRAT 11
  3. #23
    Sorry, that is the correct pid ( ignore my post about the wrong pid ).
  4. #24
    Dec 2018
    Uploading now what I got
  5. #25
    Dec 2018
ID:	23174Click image for larger version.
ID:	23175Click image for larger version.
ID:	23176Click image for larger version.
    for some reason they keep coming sideways
  6. #26
    In the 3rd pic, did you drag/drop the pid WO2CAN.WO2BEN from the rhs (under calculated pids)...?
    In the 4th pic, the data (the name of which is at the top) should be WO2BEN, not EQ_ERROR.
  7. #27
    Dec 2018
    Yes, I took the W02CAN.W02BEN from the calc pids I made.
  8. #28
    Dec 2018
    Check these out. I fixed it up, but still having issues :(
ID:	23178   Click image for larger version.
ID:	23179   Click image for larger version.
ID:	23180   Click image for larger version.
ID:	23181   Click image for larger version.
  9. #29
    Dec 2018
    I was able to get the table reading a BEN Factor with the help of a member, but it doesn't swing to a positive number or negative number. It stay at 1. See my log.
    E38_AEM Mike BEN.pld
    My Command is 0.999 basically 1.00 for Lamda. Itll go lean and rich and doesnt change the error factor so i can use it to dial in my VVE.
  10. #30
    Dec 2018
    OK BIG NEWS, IT works finally! Click image for larger version.
  1. The AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 is finally available,
    By dr.mike in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2021, 09:09 AM
  2. Replies: 2
    Last Post: March 9th, 2019, 11:59 AM
  3. Ben has a line AUTO VE Serial Wideband
    By Kr1s in forum Gen III V8 Specific
    Last Post: November 1st, 2017, 10:27 AM
  4. Got the aem w02 pid working but ben has error message
    By MattysTA in forum General (Petrol, Gas, Ethanol)
    Last Post: August 28th, 2009, 01:12 PM
  5. AEM UEGO calc_pid Ben
    By ViciousKnid in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2008, 12:33 PM
