Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: AEM 03-0334 wideband BEN
    Member ToonerSQUAD89's Avatar
    Dec 2018
    You have to log with V8.
    Do you have a screenshot of how they made a BEN map for this Wideband?
    Copy/paste the following into this file: C:\Users\YOU\Documents\EFILive\V8\Config\UserCalul atedPids.ini
    Code:
    [Groups]
    GLOBAL=Global Functions
    WO2CAN=Wideband O2 Sensors (CANbus)
    [GLOBAL]
    MAPBARO="MAP:BARO ratio",factor,3
    [GLOBAL.MAPBARO]
    0=|-- GLOBAL.MAPBARO
    1=|return pid("MAP")/pid("BARO")
    [WO2CAN]
    WO2BEN="Base Efficiency Numerator (CANbus)",factor,3
    [WO2CAN.WO2BEN]
    0=|-- WO2CAN.WO2BEN
    1=|return pid("WO2S11")/pid("EQ_RAT")
    Ignore GLOBAL.MAPBARO unless you're tuning E92 or E84.
    Remember, for pid WO2S11 you need to select AEM UEGO for the transmission controller and then under GPM select pid WO2S11.
    Dec 2018
    alright thanks! ill give it a try
    Dec 2018
    Quote Originally Posted by ToonerSQUAD89 View Post
    First off Happy New Year to Everyone. I did what you said and it still shows the Numerator stuck on 0.
    Anything you need on my end to see whats going on?
    Dec 2018
ID:	23141Click image for larger version.
ID:	23142Click image for larger version.
ID:	23143Click image for larger version.
    This is what I have so far. Car is a 2010 Camaro SS L99 E38 ECU
    AEM Wideband is reading and i have it set in lamba.
    The PID i made just stays at 0
    Im just not too seasoned on this whole calc pids thing, and im sorry for being a pain.
    is there anywhere i can watch a tutorial or a place where i can learn how to make these PIDS?
    Dec 2018
    Here are some more photos of whats going onClick image for larger version.
ID:	23145Click image for larger version.
ID:	23146Click image for larger version.
ID:	23147Click image for larger version.
    i dont know why everytime i datalog record and end i get that error
  9. #19
    Dec 2018
    Anyone? I followed the directions and still cant get this to work, becoming very frustrating.
  10. #20
    Can you post a pic showing this (can you make the pics show the right way instead of sideways, that would help me alot)...
    it could be as simple as setting the precision to non-zero.
  1. The AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 is finally available,
    By dr.mike in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2021, 09:09 AM
  2. Replies: 2
    Last Post: March 9th, 2019, 11:59 AM
  3. Ben has a line AUTO VE Serial Wideband
    By Kr1s in forum Gen III V8 Specific
    Last Post: November 1st, 2017, 10:27 AM
  4. Got the aem w02 pid working but ben has error message
    By MattysTA in forum General (Petrol, Gas, Ethanol)
    Last Post: August 28th, 2009, 01:12 PM
  5. AEM UEGO calc_pid Ben
    By ViciousKnid in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2008, 12:33 PM
