Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
Thread: AEM 03-0334 wideband BEN
  1. #41
    Member ToonerSQUAD89's Avatar
    Dec 2018
    I wish EFI live had a lot of this built in to v8 would help but i'll play around with it and make sense of it eventually, just a learning curve thats all
    MIKE
  2. #42
    Nov 2011
    Quote Originally Posted by ToonerSQUAD89 View Post
    ok ill dig into those and try to apply it to my Calc
    At this point the calc pids stuff is still baffling me, im still learning how to even make this stuff. I wish EFI live had a lot of this built in to v8 would be easier. I have a lot to learn on and step by step is not really available and a lot pertain to older controllers still
    Guess its off to go over the entire program before messing around logging and read Into Lua5.1 to understand it all
    Let me know if you need any explanation on whats happening in one of the pids/filters.
  3. #43
    Dec 2018
    Quote Originally Posted by spy2520 View Post
    Thanks really appreciate it. Ive read over your pids and understand it a little better but still need to read more into it. How do you apply the filters to the BEN map in V7 you apply the filter thru filters but not on here V8.
    I want to apply a TP changing 5% to the map as im doing this at operating temps and wont fall below 185f.
    Not sure what else i should apply. I want to try an get a very accuate and consistent map
    Also boolean...is that a rate of change meaning?
    MIKE
  4. #44
    Nov 2011
    boolean basically means true or false. Only two values can be returned.
    The rate of change calculation is dx("PID",frame()-1,frame())
    For the filters, you need to add them as part of the pid selection Click image for larger version.
    Then select the filter Click image for larger version.
    Then on "F4: Charts" you'll see a button to apply the selected filter to the right of the playback buttons. I believe this SHOULD apply to all charts, maps etc.
    You may have to reselect the data pid at the top of your map, you should see the cells change based on the filters. It doesn't always auto update the map from what i can tell.
  5. #45
    Dec 2018
    Ok im going to try it out thursday when i have free time to log. Ill let you know friday how it went. In the meantime going to keep reading and toying around with V8. The more i play around and experiment the more its making some more sense. Just a learning curve to overcome.
    MIKE
  6. #46
    Junior Member hsv084's Avatar
    Jan 2010
    Default How did you get it t work?
    OK BIG NEWS, IT works finally! Attachment 23185
    Hi ToonerSQUAD89 how did you get this to work. I'm not sure what I am doing wrong but my MAP only populates '1' in any point it moves into.
    If you want more inches stroke it
  7. #47
    Check that the the MAP axis on the map has the same units as the MAP pid that was logged.
  8. #48
    Jan 2010
    Default Confirmed pid vs axis
    Hi Joecar, Thanks for the reply. I can confirm that the pid that is logged is ECM.MAP (kPa) and my map axis is ECM.MAP (kPa).
    My progress so far can be found here: https://forum.efilive.com/showthread...4-Aem-ben-maps
    Regards Jeff
  1. The AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 is finally available,
    By dr.mike in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2021, 09:09 AM
  2. Replies: 2
    Last Post: March 9th, 2019, 11:59 AM
  3. Ben has a line AUTO VE Serial Wideband
    By Kr1s in forum Gen III V8 Specific
    Last Post: November 1st, 2017, 10:27 AM
  4. Got the aem w02 pid working but ben has error message
    By MattysTA in forum General (Petrol, Gas, Ethanol)
    Last Post: August 28th, 2009, 01:12 PM
  5. AEM UEGO calc_pid Ben
    By ViciousKnid in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2008, 12:33 PM
