Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: AEM 03-0334 wideband BEN
    Member ToonerSQUAD89's Avatar
    Dec 2018
    Default AEM 03-0334 wideband BEN
    How do I make a BEN Factor for this and create a PID? Thanks
    Dec 2018
ID:	23123Click image for larger version.
ID:	23122Click image for larger version.
ID:	23122I checked a few posts before, made my PID list and tried to make a Calc pids file for the BEN for the 0334, Is this Correct?
    Dec 2018
    Quote Originally Posted by ToonerSQUAD89 View Post
    anyone help me with this??
    Jan 2013
    i made it using the calc_pids.txt, i dont recognize the interface in your screenshots. im assuming its v8.
    the 23.49 in 017 is because my tune is scaled.
    no promises that anything here is correct, its just what i did and it seems to be working but i havent tested extensively yet.
    *CLC-00-015
    AFR 10.00 18.50 .2 "({EXT.AD1}*2.375)+7.3125"
    *CLC-00-016
    factor 10.00 18.50 .2 "14.63/{CALC.AEM_AFR_VETTE}"
    *CLC-00-017
    factor .7 1.3 .2 "23.49/{E38.AFRATIO_DMA}"
    *CLC-00-018
    factor .7 1.3 .2 "{CALC.EQ_VETTE}*({CALC.AEM_AFR_VETTE}/14.63)"
    CALC.AEM_AFR_VETTE F001 CLC-00-015 AFR Tuning "Wide Band AFR 1 - VETTE"
    CALC.WB_EQ_VETTE F001 CLC-00-016 factor Tuning "eq from wb - vette"
    CALC.EQ_VETTE F001 CLC-00-017 factor Tuning "EQ ratio scaled - vette"
    CALC.BEN_VETTE F001 CLC-00-018 factor Tuning "BEN from wb - vette"
    Are you connecting your 0334 to FSV2 using analog connection or CAN bus...?
    Are you using V7 scantool or V8 scantool...?
    Are you using two widebands (i.e a 0333 and a 0334) or just one...?
    Dec 2018
    joecar connecting via V8 Scan & Tune. one wide band 0334 only. Via CAN BUS
    Dec 2018
    i cant seem to use it in V7 or im not sure how to CAN wise
    You have to log with V8.
  1. The AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 is finally available,
    By dr.mike in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2021, 09:09 AM
  2. Replies: 2
    Last Post: March 9th, 2019, 11:59 AM
  3. Ben has a line AUTO VE Serial Wideband
    By Kr1s in forum Gen III V8 Specific
    Last Post: November 1st, 2017, 10:27 AM
  4. Got the aem w02 pid working but ben has error message
    By MattysTA in forum General (Petrol, Gas, Ethanol)
    Last Post: August 28th, 2009, 01:12 PM
  5. AEM UEGO calc_pid Ben
    By ViciousKnid in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2008, 12:33 PM
