Results 1 to 5 of 5
Thread: Can't Flash ECM but Flashes TCM Fine
    Dec 2019
    Default Can't Flash ECM but Flashes TCM Fine
    Hey All,
    I am trying to flash a Cruze 1.4ltr. The ECM was just replaced and Autocal licenses have been updated to allow additional VIN slot. It registers the new VIN and flashes without any errors. But the car will not start. If I apply the stock tune back on the car starts up fine. I can flash the TCM without any issue. Before the ECM was replaced I was able to flash it without any issues using the AutoCal. I have tried using EFILive software and the result it the same. The car has power and lights up but will not start.
    Any ideas what could be causing this?
    Have you talked to your tuner? There are so many ways to configure an AutoCal, we're shooting in the dark here trying to troubleshoot. Sounds like there's an issue with the tune file if you can successfully flash it, yet the car doesn't start, but immediately with the stock tune, the car starts. Points to the tune file IMO.
    Dec 2019
    Thanks for your response. I reached out to my tuner. He was confused as to why it did not throw errors and I have not heard back from him. He's hard to get a hold of. The tune file worked fine before the ECM was replaced. I was able to tune and revert back to stock as needed for dealer visits, etc. Is there a chance that replacing the ECM requires a new file? Can my tuner 'read' the ECM to figure out what is stopping it?
    Depends how he setup the file locking, but it shouldnt "complete" the flash then cause a no-start condition. Sounds like there may be a calibration mismatch or something. Unfortunately, you'll need your tuner to resolve these issues. I'd ask him to take the new, stock file from your ECM and create a new tune calibration from that.
    Dec 2019
    Thank you, we were able to flash it. My issue is resolved
  1. Replies: 2
    Last Post: March 6th, 2019, 07:46 PM
  2. Replies: 15
    Last Post: January 19th, 2016, 08:33 AM
  3. can't flash tcm
    By 1chevy02 in forum Allison 5 & 6 Speed
    Last Post: December 22nd, 2010, 05:42 PM
  4. Another TCM dead after re-flash
    By minytrker in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 4th, 2009, 11:52 AM
  5. Serious problem with TCM flash
    By chrleb2 in forum Allison 5 & 6 Speed
    Last Post: July 7th, 2009, 07:51 AM
