Results 1 to 2 of 2
Thread: Timing table won
    Jan 2020
    Default Timing table won
    Hi there!
    I have been having an issue with a 2006 5.9 where the timing table won’t move off of the 0mm3 column, it is commanding proper fuel and rail pressure, but the truck feels doggy and unresponsive. I will include pictures of the data log, playing it back in v7.5 shows that the 0.0 mm3 column is where the truck is following the table and won’t move past that, and the RPM moves across the outside column like normal. I am wondering if I am in some sort of engine limp/safe mode from a bad sensor? Or if I’m logging be wrong parameter? Has anyone else had this issue before?
    Max
ID:	23158   Click image for larger version.
    This is just a Scan tool -> Tune tool linking issue, the Scan tool is working and logging what the truck is actually doing.
    Browse to "C:\Program Files (x86)\EFILive\V7.5\Configuration" and find the the <insert ECM codename>_link.cfg file for this ECM, open it and ensure the table links and units are set up properly.
  1. E92 throttle won't go past 33%
    By 04colyZQ8 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: October 12th, 2018, 05:43 AM
  2. 2012 LS3 won't rev past 5700 codes P0100& P0400
    By TurboCamaro in forum E37, E38 & E67 PFI ECM's
    Last Post: June 1st, 2017, 02:04 PM
  3. 2012 5.3 truck with 6l80e (vette tune) won't move.
    By bubba68ss in forum Gen IV V8 Specific
    Last Post: November 3rd, 2016, 03:21 PM
  4. Creating a one column table.
    By 2002_z28_six_speed in forum General
    Last Post: August 5th, 2007, 09:56 AM
  5. LS2 Transplant won't go past idle.
    By Scoota in forum Gen IV V8 Specific
    Last Post: April 20th, 2007, 05:57 PM
