Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Need some help updated tune and now limiting fuel
    Apr 2008
    Quote Originally Posted by Dom_c13b View Post
    You need to raise the RPM limits under the engine protection tabs. Bring them all up to 6000ish or higher and then use your throttle table or boost limit table to limit your overall engine speed/max RPM.
    Thanks I will give it a shot and see what happens.
    Still can understand why it was fueling fine then did an adjustment to the trans 3-4 shift and took some timing out of #3 and now this is happening.
    Apr 2008
    Quote Originally Posted by arinkuddy View Post
    I would try what Dom_c13b said. I did not see anything that should be holding you back. Even the RPM limiters seemed ok to me (I am on a manual). I run the following
    Attachment 23173
    If that does not work try the old tune again and run a diff on it to see what changed.
    I think something has gotten corrupted maybe something the ECU is seeing when its running. I don't know. I flashed the old tune back in after I started seeing the fueling problem. It is doing the same thing and now limiting fuel. My old data log files clearly show full fueling. I'm stumped.
    Member arinkuddy's Avatar
    May 2014
    One thing I noticed that is odd is your boot sensor table. Why do you have it like this?
Name:	Annotation 2020-01-23 165910.png
    Apr 2008
    There was a old thread of someone having a similar issue that I am and it was recommend to him to do this and it fixed his problem. Figured I'd give it a try just haven't put it back to original settings yet.
    Apr 2008
    Still no luck getting full fueling. Does anyone have a stock 11352409 48re Auto OS someone is willing to share. Searching this issue has led me to others having this similar problem with with some 602 OS's and auto trans. I have found 409 manuals but no autos. Thanks in advance for the help.
    Apr 2008
    Quote Originally Posted by blackshadow View Post
    PM me email and I'll send you all the slides I have. They are getting pretty old now.
    Could you send them to nm2769@gmail.com
    Senior Member tylerltr450's Avatar
    Aug 2014
    Quote Originally Posted by nm2769 View Post
    here
    2007 Auto 409 Stock.ctz
    2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
    Apr 2008
    Quote Originally Posted by tylerltr450 View Post
    Thanks I appreciate it.
  9. #19
    Apr 2008
    409 OS solved my issue. Thanks guys for the input and support.
  1. fuel limiting before 3200
    By 85c20lb7 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 27th, 2018, 08:17 PM
  2. Updated tune, now stuck on low octane table?
    By ddnspider in forum Gen III V8 Specific
    Last Post: October 19th, 2012, 01:40 PM
  3. Updated Stock Tune
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 13th, 2010, 07:09 AM
  4. New updated 2010 Camaro tune file?
    By RonC in forum Gen IV V8 Specific
    Last Post: August 27th, 2009, 12:59 PM
  5. LBZ log and fuel limiting
    Last Post: August 2nd, 2009, 03:26 AM
