Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Tuning question Road tuning
    Member ToonerSQUAD89's Avatar
    Dec 2018
    Yea the VE table is so much easier. The VVE is giving me fits. If i get the car to operating temp, drive it and log driving in D and then try it again shifting manually the BEN map is completely opposite.
    So manually editing is the only way along with Ben #s? And setting correct boundaries can you elaborate on how? You mean matching the correct KPA to zone?
    Also if Going back to the MAF when i do, you log the parameters in that guide and make a hystogram map of what? I have not done the MAF yet, i see in the guide was Pids to select that was it.
    Aug 2013
    Understand this.... SD sucks at the best of times. Don't put too much effort into it unless you intend on running SD full time. Until you have a better idea of what you're doing, I'd suggest leaving the factory VVE tables and boundaries and just tune the MAF.
    I'm not here to teach you how to tune, but I will say this..... Make sure you always have PE enabled. Make sure you're in open loop if you're tuning exclusively with wideband. Make sure you apply transient filters. And always log for KR when you're logging.
    Dec 2018
    Up until today i was always had PE enabled. Just went to try something different and went off course shall we say from some frustration to try another method, yes i know now i look at it made no sense now. Yes open loop of course and the rest of what you mentioned i have been doing. Im just trying to set myself up and most importantly know what parameters im changing. I plan on taking in alot this year and its a tedious process. I really want to get the VVE table done correctly though
    To reinforce what statesman said above, NEVER turn off PE... make sure PE is sufgiciently rich, and make sure it enables promptly... and look/listen for knock.
    Disable one air source while correcting/tuning the other, and disable all forms of trimming (including OL STFT).
    Transient filter is very important. Try to tune on a loadable dyno rather than the street.
    For E38 and E67 try and see if you can use SAE.LAMBDA if it works (you may have to check its sense).
    ( GM.AFRATIO_DMA (_M) does not always work correctly on all ECM's )
    Don't worry above the VVE zone boundaries, they should already be in the right places.
    Dec 2018
    Transient filter are they different to apply in V8, i know in V7 how to but v8 not so much
    Dec 2018
    Update...i am figuring it out. I got a cruise parts of my map to be steady at 1.00 to .0998. The manual blending is the real struggle especially looking at a blaring red background on those tables
    MIKE
  9. #19
    Aug 2013
    Quote Originally Posted by ToonerSQUAD89 View Post
    It's a steep learning curve, but with perseverance you'll get there.
  10. #20
    Dec 2018
    Quote Originally Posted by statesman View Post
    Yea definitely. Taking the time to experiment with things in V8 and also tune tool has helped alot. Still have a lot more to explore but its a great feeling that its all coming together and understanding it. Once i do a few more logs focusing on different sections itll get dialed in and ill do the MAF and then re-enable it to have a MAF+SD tune and ill re enable trims to help with any deviations that do occur out of my control
    MIKE
  1. Road question tuning cant figure it out with my camaro
    By ToonerSQUAD89 in forum E37, E38 & E67 PFI ECM's
    Last Post: January 26th, 2020, 01:12 PM
  2. 2013 cummins off road tuning
    By dieselpro55 in forum Diesel
    Last Post: May 12th, 2017, 10:46 PM
  3. Question about road runner
    By J.Abbott in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 24th, 2013, 09:02 AM
  4. tuning question
    By 1hotduramax in forum Duramax LB7
    Last Post: September 30th, 2008, 03:34 PM
  5. Real Time tuning w/o Road Runner?
    By Treed ya in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2008, 06:40 PM
