Results 1 to 7 of 7
Thread: Tire Rev Calubration
    Aug 2019
    Default Tire Rev Calubration
    Is there any chance you guys will add tire revs per mile so we can change tire size in internal flash? It seems you guys had it in the 5.9s but stopped after that. Is that correct?
    I think it is handled in another module on the later vehicles (someone may correct me on that).
    Aug 2019
    Okay, dang was hoping we could add that in. Thanks for letting me know.
    Senior Member Jim P's Avatar
    Nov 2019
    It's handled in the ECM, at least on the 2007.5-2012. It's in tire revs/km, 3 parameters, 2 parameters with the same value, 395.xxxx revs/km than the third is some "tire size adjustment after wear" parameter with a value of something like 315.xxx revs/km.
    Oct 2012
    Quote Originally Posted by Jim P View Post
    I think what you're referring to is used to calculate the N/V load. The speedometer is controlled by the BCM module in the 13 and newer trucks.
    AlfaOBD or a HyperTech tire calibrator is what I use to adjust the speedometer.
    Aug 2019
    thank you I will look into that.
    Lifetime Member Road's Avatar
    Feb 2015
    A good scan tool like a snap on will allow tire calibration.
  1. tire correction
    By LMMPerrona in forum Cummins 6.7L
    Last Post: February 23rd, 2015, 04:45 AM
  2. Tire size help
    By 08pearlZ06 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 23rd, 2014, 03:37 AM
  3. Tire change
    By 69camaro5speed in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 4th, 2011, 01:20 PM
  4. Change a tire ...
    By Garry in forum Lounge
    Last Post: September 21st, 2008, 06:07 PM
