Results 1 to 10 of 11
Thread: E92 Alpha-N (RPM vs TPS) Tuning
    Feb 2020
    Default E92 Alpha-N (RPM vs TPS) Tuning
    Does the E92 ECM support Alpha-N (RPM vs TPS) tuning in stock form? If so, how would I go about configuring the ECM to operate in said mode? If not, can a custom OS be applied or developed to/for this ECM to support Alpha-N based tuning? My apologizes if this is posted in the wrong sub-forum.
    Feb 2020
    I'll take that as a 'no' then?
    Lifetime Member ProperTuningOG's Avatar
    Dec 2014
    What app has you needing alpha-n?
    Feb 2020
    2019 5.3 with Individual Throttle Bodies. Nothing crazy, trying to see if the E92 ECM is capable of handling these - else I'll just stick with a traditional SBC/ BBC.
    If there was a standalone ecu available for these motors and a 6L transmission, I would of gone that way, but alas - the aftermarket has yet to catch up.
    Like I said, nothing crazy. 5.3, ITB's, 8K rpm, and some Q16. I had a B20V with this exact formula, made 263 whp at 8K rpm; had a CNC'd head built for 11k RPM, but sold the setup before I dyno'd it. Figured a screaming 5.3 would make for some fun.
    I originally had plans to go with VP's M5, but that would require a completely different fuel system - which doesn't exist in the aftermarket - yet.
    Feb 2020
    Also, I am a C programmer. If it's a matter of modifying a binary or working with hex dumps, I have no issues with that.
    Dec 2014
    There's aftermarket options. We are working with Emtron on them. DI with 6L or 4L will be testing shortly.
    As far as the E92. We will have Mefi 7 ready soon for public consumer.
    Feb 2020
    Very interesting. For clarification, the unit being developed with Emtron; is that a full standalone with integrated 6L support, or is the 6L side of things a separate module?
    Regarding MEFI 7, is that a standalone replacement for the E92? Wire-in, pin-compatible,...
    Would I be correct in assuming the two proposed controller stacks are:
    (1) Emtron (+ Emtron TCM?)
    (2) MEFI 7 + (Some 6L controller)
    or...
    (1) Emtron + MEFI 7 (Emtron handling the transmission side and MEFI 7 handling the engine side of things?)
    Dec 2014
    Both are single controller, no secondary needed. Mefi 7 is an E92.... What rig will this be in? Do you need to retain full chassis CAN messaging?
    Feb 2020
    That's awesome. This application is a 2019 Silverado (2wd), 5.3 with a 6L. The ability to retain full chassis CAN messaging would be nice, but not a must; would the MEFI 7 be the better choice in this case?
    On that note, could the Emtron unit be used to control a 6L transmission behind a mechanically injected engine, e.g. (Enderle). If so, what inputs would be required? RPM, TPS, ...
    Dec 2014
    I really don't want to clog up the forum and make this sound like an ad or self promotion. Feel free to send me an email. Josh@custombuiltmotors.com
  1. Off Idle Stumble - Erratic TPS and RPM Swings
    By LastCall in forum Gen IV V8 Specific
    Last Post: February 26th, 2017, 12:40 PM
  2. TPS vs RPM
    By Gordy M in forum Gen III V8 Specific
    Last Post: October 22nd, 2015, 01:52 AM
  3. Alpha N (TPS Load) help... noisy TPS signal?
    By Tomato in forum Gen III V8 Specific
    Last Post: July 4th, 2008, 10:22 PM
  4. Knock sensor multiplier (6244, 45, 50 & 55) TPS, RPM and
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2007, 04:59 AM
  5. VE Multiplier vs. TPS vs. RPM table, with non-linear TPS...
    By SSbaby in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2005, 11:46 AM
