Results 1 to 7 of 7
Thread: Making dual electric fans work without having to segment swap
    Mar 2007
    Default Making dual electric fans work without having to segment swap
    Looking for some help to verify that I can make dual electric fans work on a vehicle other than the Camaro / Corvette (e.g. - not having to do a system segment swap). I have gone through the code in a 2001 disassembly and think that I found out why the regular EFILive parameters won't allow it. There is another parameter that pertains to the 2nd fan which is not currently in the EFILive. I created a CAX file for this additional parameter that seems to make it work. I have checked in on my bench 0411 using a 2002 OS, but would like to have someone else verify it on an actual vehicle. If you are willing to give it a try please let me know (FWIW - I am pretty sure I can find the correct parameter in any 512 kB OS).
    Jun 2009
    Running dual fans with Nelson harness in 2000 Yukon XL (12212156 OS)
    G1203 set to "Series Parallel Fans"
    G0106 set to "Fan #2 Control"
    Fan settings from 2005 truck
    2007.5 CCSB LMM 4x4
    PPE Stg V, ML, 4094va, EFI Live DSP5, manifolds, up pipes, SS 4" exhaust, EGT, Boost, and DP gauges, 1R-0749, and 256-8753 CAT filters on Nicktane heads, lift pump on Kennedy harness, Yukon Grizzly
    Mar 2007
    It sounds like you are using a 1 MB PCM in your swap. Yes, the 2005 truck settings do work, since that is the way they were setup from the factory. I am hoping to show that for the older 512 kB PCM's that you can make them work too. I am running an older version of EFI Live, and maybe somebody added in the parameters into the newest version to make it work too.
    Ive never had a issue running dual fans from a 12212156 OS.
    What are you trying to do?
    These are the settings i have been using.
ID:	23199Click image for larger version.
    12212156 allows you to run dual fans F-car style using 3 relays.
    Mar 2007
    Yes, for the F body and Corvettes / Holdens, it works using 3 replays. The issue that arises is that there are two parameters which I believe are missing from the list which on say truck OS's, are set to zero which prevents Fan #2 from turning on. I would like for someone to try it to see if they can now get Fan #2 to turn on. My research is showing that you would NOT have to do any segment swapping to get Fan #2 to work. I think that you would also NOT have to hook up the A/C pressure sensor to get it to work either.
    Quote Originally Posted by turbo_bu View Post
    My fan 2 output works just fine on a truck OS.
    Want me to send you my tune?
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  1. Electric fans
    By Kunz111 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 31st, 2015, 02:25 PM
  2. electric Fans
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2013, 05:01 PM
  3. making a 6.0 swap work - best way?
    By Boost in forum Gen III V8 Specific
    Last Post: May 17th, 2011, 11:40 PM
  4. Who's converted an '02 6.0 truck to electric fans?
    By HTMtrSprt in forum Gen III V8 Specific
    Last Post: March 9th, 2009, 01:58 AM
  5. PIN out #'s for Electric Fans
    By MN C5 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 13th, 2008, 10:14 PM
