Results 1 to 4 of 4
Thread: Tuning transmission for single wire park/neutral input
    Oct 2016
    Default Tuning transmission for single wire park/neutral input
    Is there a way to tune 02 silverado 5.3l/4.l60e ecm to accept a single wire park/neutral on pin 34?
    Mar 2007
    The Camaro is setup that way. There is a gear indicator CAX file which should allow you to make this change.
    Oct 2016
    found the cax files. thanks
    May 2019
    Location of the cax files? Please? I'm having this same issue
  1. cant change Park neutral rev limiter
    By Gmarine in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: April 12th, 2017, 06:05 AM
  2. Replies: 9
    Last Post: September 22nd, 2016, 08:45 AM
  3. Engine Conversions and Park/Neutral Signal
    Last Post: March 18th, 2013, 04:12 AM
  4. Conquering Park/Neutral Signal and Gear Selector Switch (PNP)
    Last Post: May 29th, 2009, 10:53 PM
  5. Can't get my truck to use the idle park/neutral tables
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: October 17th, 2005, 02:05 PM
