Results 1 to 3 of 3
Thread: Serial Cable
    Senior Member blsnelling's Avatar
    Sep 2010
    Default Serial Cable
    Will this cable work on my V2? I don't have the original and need to connect to my LC-2 Wideband O2.
    https://www.amazon.com/gp/product/B0...DBUTQX3J&psc=1
    '01 ECSB 4x4, '04 6.0L LQ4 Shortblock, 243 Heads Milled .035 11:1 Compression, Pac 1218 Springs, Yank PT3200 Stall, Comp Cam 220/224, .581/.581, 112LSA, LS7 Lifters, TBSS Intake Manifold, Edelbrock 3864 90mm T-Body, Doug Thorley LT Tri-Y ceramic headers, Flowmaster 50 SUV, LS1 e-fans, Airaid MIT, Complete valve body build up, 4.30:1 Gears, 33/12.50-17 Tires
    It might... if it doesn't then the RX and Tx pins might need to be swapped.
    Sep 2010
  1. Flashscan to LM-2 Serial Cable
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: May 2nd, 2016, 09:36 AM
  2. LC-2 to V2 serial cable ?
    By ssstreetcar in forum General
    Last Post: November 4th, 2014, 08:34 AM
  3. V2 Serial Cable
    By Mike@Vengeance in forum FlashScan V2
    Last Post: September 9th, 2013, 07:20 AM
  4. Pin # on serial cable on v2 q
    By restless@westnet.com.au in forum FlashScan V2
    Last Post: May 10th, 2013, 06:05 PM
  5. serial cable
    By stick100 in forum General
    Last Post: April 22nd, 2012, 09:42 PM
