Will this cable work on my V2? I don't have the original and need to connect to my LC-2 Wideband O2.
https://www.amazon.com/gp/product/B0...DBUTQX3J&psc=1
'01 ECSB 4x4, '04 6.0L LQ4 Shortblock, 243 Heads Milled .035 11:1 Compression, Pac 1218 Springs, Yank PT3200 Stall, Comp Cam 220/224, .581/.581, 112LSA, LS7 Lifters, TBSS Intake Manifold, Edelbrock 3864 90mm T-Body, Doug Thorley LT Tri-Y ceramic headers, Flowmaster 50 SUV, LS1 e-fans, Airaid MIT, Complete valve body build up, 4.30:1 Gears, 33/12.50-17 Tires
It might... if it doesn't then the RX and Tx pins might need to be swapped.
