Thread: Injector Calibrations
    Dec 2019
    Default Injector Calibrations
    Does anybody know if there's an easy way to program injector calibrations into the ecm AND gpm? Right now, they're both empty. When I try to read, they both say "no data"
    I had "injector calibration incorrect" codes, and was following instructions on another forum. Now I think I just ended up completely wiping the data.
    And could those injector calibrations codes even have been what was stopping the truck from starting in the first place?
    I just keep falling farther and farther down the rabbit hole...
    Actually I am not sure what you can do in this situation. I'm trying to think how GM TechII would handle this and from memory it only had the option to copy the codes from one module to another, but when they are both blank I don't know what can be done.
    If memory serves, the code is laser etched onto the injectors. So you could copy those down and with a tech 2, you could program each injector into the ecm individually. I know I was able to program a new code in with my tech 2 when I had to replace an injector.
    Sent from my 2PZC5 using Tapatalk
    Dec 2019
    Ok thanks. I was hoping that it would be stored in a previous tune file or something, or that efi live would be able to do it. I know I've heard people say that it's not absolutely essential to update the data when you install new injectors. But the fact that I no longer have any data for the computer to reference, is probably no good. I'm really new to all of this, and that was a pretty stupid mistake I just made. The injectors were reading good in the ECM. All I had to do was program them to the GPM.
    In hindsight, I think my problem was that I wasnt following the proper procedure. To copy the codes from the ECM to the GPM, I believe I should have used these simple operations:
    -Read Ecm Inject.
    -Program GPM Inject.
    But instead, I was following an instruction list for copying in the opposite direction. Not my brightest moment.
    Unfortunately on the Bosch ECM's when we read them the stored Injector codes aren't saved.
    Dec 2019
    Just my luck, lol. Thanks
  1. Website for calibrations
    By J.Abbott in forum Gen IV V8 Specific
    Last Post: February 20th, 2013, 10:05 AM
  2. MAF calibrations
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 30th, 2009, 10:06 AM
  3. LBZ Calibrations
    By Ultimate Diesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 25th, 2008, 10:44 AM
  4. OS Calibrations
    By Spindoctor in forum General (Diesel)
    Last Post: May 7th, 2008, 10:11 AM
  5. 85mm MAF calibrations
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 27th, 2005, 06:19 AM
