Originally Posted by
Krapovnitsky
Thought about that. Thought about tweaking injection pulse time also. The problem is that we can not tweak these parameters only for a second, there is no transient tables for that. It still could workaround the issue only in case if ECU takes injection parameters for that second out of some fixed tables not related to mixture tables we can edit. Then if we intentionally tweak air tables 1.5 times down or pulse tables 1.5 times down (slightly harder to do) and enrich mixture 1.5 times then resulting mixture remaining the same but their internal hidden tables are 1.5 times leaner now, what we want. If enriching for that second based on the same mixture tables we edit (ECU OS dividing numbers by 1.5 times lets say) then resulting mixture will always be adjusted after all our tweaks and result will not change. I can try it and report results here for others. I am just too disappointed and sick of it, that is why I still did not try it for myself. We need a proper solution, not a hack rising more issues in the future.
