Thread: Reading Cms controllers in pass though mode not possible
    Feb 2020
    Default Reading Cms controllers in pass though mode not possible
    Hello everyone please help with information
    How to read out internal flash out of Cummins pcm what tools required or software if possible . Does any anyone have cummins controllers (pcm) list and chart of reading capabilities for specific pcm number and flash size file format of flash memory . Or if I need to purchase additional Lisence for efi live v2 .
    Depends on the ECM type.
    All HD based ones can be read out, only 2006-2009 Dodge ones can be read out, 2010+ cannot.
    Feb 2020
    I noticed when I hooked up to 2011 ram Cummins 6.7 with v2 I sayid can read pass true mode meaningful there is alternative write?
    You can't read a 2011 via OBD-II, I can't think of how the software would have allowed that selection to happen because that ECM is not even available to manually select as a readable ECM.
    I cannot understand your last question.
    Feb 2020
    Is there any engendering tools or software which it can be done
    I don't believe so (well, I don't know to be honest never having worked at Cummins), it is only the Dodge ECM's that are like this so I guess they wanted them better protected.
    You can download the stock files from here though, you just need to identify what is in the ECM first.
    https://forum.efilive.com/showthread...k-tune-library
  1. Can't record Analog voltages in pass through mode!!!
    By 2002_z28_six_speed in forum External A/D inputs
    Last Post: September 7th, 2015, 05:29 PM
  2. UPDATE: V8 Pass-Through Reading/Flashing Support (pre-release)
    Last Post: November 18th, 2010, 05:59 AM
  3. V8 Pass-Through Reading/Flashing Support (pre-release)
    Last Post: October 15th, 2010, 05:53 PM
  4. V8 Pass-Through Reading Support (pre-release)
    Last Post: October 8th, 2010, 10:03 AM
