Results 1 to 10 of 14
Thread: '13 truck had LC9, swapped to LY6
    Mar 2020
    Default '13 truck had LC9, swapped to LY6
    Hey, could anyone post up a ly6 tune that's compatible with me e38 ecu??? Can't script because all I can find are incompatible OS's. My os is 12653674. I tried just copying and pasting tables but the 07 ly6 tune has tables that are not identical to the 5.3's
    Dec 2016
    Hello,
    I think '07-'08 Truck E38's are by themselves and '09-'15 Truck E38's should be similar. I have a file from a 2009 Express Van LY6 but it's not in efilive format and would take me a few days to do since I am buried at work. I have all the stuff to make a bench E38 programming station but haven't made the time to do it yet. :( If you don't find one, post back here. Also post your stock file so I can look at it in efilive and see if the structure looks like this '09.
    -CarlClick image for larger version.
    Mar 2020
    No luck finding a stock tune anywhere, I'm posting the lc9 tune up. Would the l96 have the same tables as the ly6 minus the injector flow? And flex fuel of course?E38 5.3 2013 sierra 12653674.ctz
    Dec 2016
    Hello,
    I noticed quite a few changes in your file compared to a stock '13 5.3 file. Is this an engine swap in a different vehicle? Are you still using the stock air inlet/maf tube? If not, please state what you are using for that as it is critical. The VVE of course is way different between engines. Yes, the injector data is different between the two engines. I see you changed the MAP sensor values too, are they accurate now?
    -Carl
    Dec 2016
    Here is the injector data you need for the LY6
    Code:
    	Injector Offset (msec) Vs Delta Pressure Vs Ignition Voltage
      Volts        kPa
               128   148   168   188   208   228   248   268   288   308   328   348   368   388   408   428   448   468   488   508   528   548   568   588   608   628   648   668   688   708   728   748   768
       4.0    6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00
       5.0    6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00
       6.0    5.77  5.81  5.84  5.87  5.89  5.92  5.94  5.96  5.98  5.99  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00
       7.0    2.41  2.60  2.77  2.92  3.05  3.18  3.30  3.40  3.49  3.59  3.80  4.19  4.56  4.91  5.21  5.45  5.66  5.88  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00  6.00
       8.0    1.77  1.84  1.91  1.96  2.01  2.05  2.09  2.13  2.16  2.20  2.25  2.31  2.38  2.45  2.52  2.61  2.69  2.77  2.98  3.39  3.78  4.16  4.52  4.87  5.21  5.53  5.73  5.73  5.73  5.73  5.73  5.73  5.73
       9.0    1.45  1.49  1.54  1.58  1.62  1.66  1.69  1.71  1.73  1.77  1.80  1.84  1.88  1.93  1.98  2.04  2.09  2.15  2.27  2.49  2.71  2.91  3.12  3.31  3.50  3.68  3.78  3.78  3.78  3.78  3.78  3.78  3.78
      10.0    1.12  1.15  1.18  1.20  1.23  1.25  1.27  1.29  1.30  1.32  1.34  1.37  1.39  1.41  1.44  1.46  1.49  1.52  1.55  1.60  1.64  1.68  1.72  1.75  1.78  1.82  1.84  1.84  1.84  1.84  1.84  1.84  1.84
      11.0    0.96  0.98  1.01  1.03  1.05  1.07  1.09  1.10  1.11  1.13  1.14  1.16  1.18  1.20  1.22  1.24  1.27  1.29  1.31  1.34  1.38  1.41  1.44  1.46  1.48  1.52  1.52  1.52  1.52  1.52  1.52  1.52  1.52
      12.0    0.80  0.83  0.84  0.86  0.87  0.88  0.90  0.91  0.91  0.92  0.94  0.95  0.97  0.98  0.99  1.02  1.03  1.05  1.06  1.09  1.11  1.13  1.15  1.17  1.19  1.20  1.21  1.21  1.21  1.21  1.21  1.21  1.21
      13.0    0.70  0.72  0.73  0.75  0.76  0.77  0.78  0.79  0.80  0.80  0.81  0.83  0.84  0.85  0.87  0.88  0.89  0.91  0.92  0.95  0.96  0.98  1.00  1.02  1.04  1.05  1.06  1.06  1.06  1.06  1.06  1.06  1.06
      14.0    0.60  0.61  0.63  0.63  0.64  0.65  0.66  0.66  0.67  0.68  0.69  0.70  0.71  0.72  0.73  0.74  0.76  0.77  0.78  0.80  0.82  0.84  0.86  0.88  0.89  0.91  0.91  0.91  0.91  0.91  0.91  0.91  0.91
      15.0    0.53  0.54  0.55  0.56  0.56  0.57  0.58  0.59  0.59  0.59  0.60  0.62  0.63  0.63  0.65  0.66  0.66  0.67  0.69  0.71  0.72  0.73  0.75  0.77  0.78  0.79  0.80  0.80  0.80  0.80  0.80  0.80  0.80
      16.0    0.46  0.47  0.48  0.48  0.48  0.49  0.50  0.50  0.51  0.51  0.52  0.53  0.54  0.55  0.56  0.57  0.58  0.59  0.60  0.62  0.63  0.63  0.65  0.66  0.66  0.67  0.68  0.68  0.68  0.68  0.68  0.68  0.68
      17.0    0.41  0.41  0.43  0.43  0.44  0.44  0.45  0.45  0.45  0.45  0.46  0.47  0.48  0.48  0.50  0.51  0.52  0.52  0.54  0.55  0.56  0.57  0.59  0.59  0.60  0.61  0.62  0.62  0.62  0.62  0.62  0.62  0.62
      18.0    0.36  0.37  0.38  0.38  0.38  0.38  0.39  0.39  0.40  0.40  0.41  0.41  0.42  0.43  0.45  0.45  0.45  0.46  0.48  0.48  0.49  0.51  0.52  0.52  0.53  0.54  0.55  0.55  0.55  0.55  0.55  0.55  0.55
      19.0    0.31  0.32  0.32  0.33  0.33  0.34  0.34  0.34  0.34  0.34  0.35  0.36  0.37  0.37  0.38  0.39  0.40  0.40  0.41  0.42  0.43  0.44  0.45  0.46  0.47  0.48  0.48  0.48  0.48  0.48  0.48  0.48  0.48
      20.0    0.27  0.27  0.27  0.27  0.28  0.28  0.28  0.29  0.29  0.29  0.30  0.30  0.30  0.31  0.32  0.33  0.34  0.34  0.35  0.36  0.37  0.38  0.39  0.39  0.40  0.41  0.41  0.41  0.41  0.41  0.41  0.41  0.41
     	Injector Flow Rate Vs. Delta Pressure
       kPa   gm/sec
        128  2.412
        148  2.554
        168  2.696
        188  2.838
        208  2.980
        228  3.122
        248  3.265
        268  3.407
        288  3.549
        308  3.691
        328  3.822
        348  3.934
        368  4.047
        388  4.159
        408  4.270
        428  4.378
        448  4.486
        468  4.594
        488  4.696
        508  4.790
        528  4.885
        548  4.979
        568  5.073
        588  5.167
        608  5.262
        628  5.356
        648  5.412
        668  5.412
        688  5.412
        708  5.412
        728  5.412
        748  5.412
        768  5.412
    Mar 2020
    So I must have sent the wrong file. I had to adjust the map, and the injector data just to get the truck to idle and drive. The truck is a 13 that originally had an lc9. The motor threw a rod and I swapped in an 07 ly6 6.0 out of a van.
    Mar 2020
    Quote Originally Posted by In-Tech View Post
    Code:
      Volts        kPa
       kPa   gm/sec
        128  2.412
        148  2.554
        168  2.696
        188  2.838
        208  2.980
        228  3.122
        248  3.265
        268  3.407
        288  3.549
        308  3.691
        328  3.822
        348  3.934
        368  4.047
        388  4.159
        408  4.270
        428  4.378
        448  4.486
        468  4.594
        488  4.696
        508  4.790
        528  4.885
        548  4.979
        568  5.073
        588  5.167
        608  5.262
        628  5.356
        648  5.412
        668  5.412
        688  5.412
        708  5.412
        728  5.412
        748  5.412
        768  5.412
    Perfect, I will just need to adjust the VVE after correct?
    Dec 2016
    Change B0104 Cylinder Volume to .75 so ecm thinks it is a 6L
    Once we can set your MAF transfer function to correct values, turn off VVE by changing B8024,5 to 400,300rpm respectively. We can put the LY6 VVE in after I can get you a LY6 file to copy from. Put your map sensor slope and offset back to stock if using the stock sensor.
    Mar 2020
    Okay! Will do
    Dec 2016
    If the truck intake air system is still stock, use the stock MAF transfer function, correct the fuel tables I posted, set the cylinder volume to .75 and put the stock MAP settings back in. Turn off the VVE for now and it should start and run. I assume you are using the stock LY6 injectors?
    Curious, does the LY6 have cathedral heads or LS3/L92 rectangular type?
  1. 2010+ LY6 E38 calibration
    By gixxer92 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 31st, 2019, 12:32 PM
  2. 2012 LY6 with 6L90e E38 or E78 PCM
    By Age08 in forum Gen IV V8 Specific
    Last Post: January 21st, 2015, 01:00 PM
  3. LC9 to L76 swap
    By Maxirat427 in forum Gen IV V8 Specific
    Last Post: November 24th, 2014, 11:59 AM
  4. LY6 swap on Monte Carlo wont start
    By blazinblue in forum E37, E38 & E67 PFI ECM's
    Last Post: April 3rd, 2012, 02:37 AM
  5. Tuning for 2008 6.0L LY6 in 2500HD
    By ZigBlazer in forum General (Petrol, Gas, Ethanol)
    Last Post: November 21st, 2010, 03:52 AM
