Results 1 to 3 of 3
Thread: Stand Alone E80
    Jan 2009
    Default Stand Alone E80
    I'm helping a friend put a 2016 Camaro SIDI turbo I4 into a older Triumph. In OEM configuration the "On/Start" signal appears to come from the BCM. Does anyone know if the E80 can be made to stand alone?
    I'm assuming you'll need to just bypass all that and have the starter wired up old school style via the Start position on the IGN switch and of course a neutral safety switch as well.
    Dec 2014
    We run them in sandrails and air boats, no prob.
  1. E80 LTG Camaro Help
    By DarkFangz1100 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 25th, 2019, 02:44 PM
  2. E80 won't unlock
    By Boost in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 28th, 2019, 01:49 AM
  3. Need help with calibration E80 camaro.
    By Madcat in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: May 15th, 2018, 05:55 AM
  4. E80 VATS Patch
    By jrz in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 13th, 2017, 12:01 PM
  5. E80 Boost target
    By Giambals in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 20th, 2017, 05:40 AM
