Results 1 to 2 of 2
Thread: Lmm with tunes from Danville
    Mar 2020
    Default Lmm with tunes from Danville
    I just recently bought a 2007.5 duramax. It has a 5 position switch with a efi tunes. I have no idea what tune is what on the switch. I would also like to potentially edit one of the tunes so that it will hiss at idle. I got no tuner or anything with it. What would I need to accomplish this. I have hp tuners but I don
    Oct 2020
    im new to this so bare with me if im incorrect. you first need permission to use the file from danville. secondly in order to make changes to the file you need to have V8 software installed as well as a Flashscan V2. as well as a license. im still learning myself but if you contact Danville they should be more than happy to assist you with your needs as well as provide insight as to which step you should take next. honesty is key just explain to them what you just explained to us. hope this helps.
  1. LMM Tunes with turbo brake
    By Outlaw Street in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 8th, 2020, 05:15 AM
  2. Need Help On LMM Tunes
    By SmokeSmacked02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 5th, 2012, 01:27 PM
  3. Locking tunes to email for LMM/LBZ
    Last Post: March 22nd, 2011, 11:40 AM
  4. LMM TCM tunes
    By Nor-Cal Nick in forum Allison 5 & 6 Speed
    Last Post: November 6th, 2008, 01:50 PM
  5. need mileage tunes for lmm
    By farmer79 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 30th, 2008, 07:24 AM
