Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 6.0 Vortec Towing Tune
    Mar 2020
    Default 6.0 Vortec Towing Tune
    Hey everyone,
    I am new to this EFILive Life but so far i am way impressed by the way everyone helps each other out! That being said I have a 03 GMC Sierra 2500HD 4WD (LS1b Gen III ) with the 4L80e Transmission. I have a Volant Cold Air Intake w/Underbody Snorkel, Volant Throttle Body Spacer, Pacesetter Long Tube Headers, FlowMaster High Flow Cats with a Magnaflow Dual in/out Muffler. I tow a 30ft toy hauler that weighs about 11,000 lbs Loaded. I am trying to get some extra torque so its not so sluggish and hopefully to help the overheating issues. I am not to worried about gas mileage as the truck is paid off and is alot cheaper than a new truck Is there a tune already set up for this or do i need to start fresh? I have been reading post after post about similar situations but none that match my current setup.
    I would appreciate any help i can get!
    03 GMC Sierra 2500HD - LS1b 6.0L Vortec with the 480LE Trans. Mods = Volant Cold Air Intake, Volant Throttle Body Spacer, Pacesetter Headers, Flowmaster High Flow Cats, Magnaflow Muffler and EFILive PCM Tuner.
    If you want to just flash a tune and not think about it, I'd suggest contacting a tuning shop who can put together a baseline tune for what you're looking for.
    If you want to learn how to build a tune for your setup, that's where the forum can help. The LS1B PCM is pretty simple to get good results from, you will need to purchase a wideband O2 sensor so you can ensure the Air/Fuel ratio is correct, otherwise you just need a FlashScan V2 w/GM Tuning. Look up the Calc.VET tutorial on here, it will walk you through what's needed to dial in your VE and MAF tables. For spark, you'll need to log knock and see if you're getting any knock then look to optimize the spark tables.
    Mar 2020
    Thanks ScarabEpic22! I Definitely want to learn how to tune it myself I have been reading multiple threads on this forum and have been writing down notes on do's and dont's but it seems a lot of the stuff i try it doesn't work? I know i am missing something minor and it is a little frustrating but i am not giving up! I purchased the Flashscan V2 w/GM Tune a few weeks ago and i have been playing with it to get a feel for it. I tried to do a log on Saturday after i set up the CALC.VET file along with the list of PIDs to activate but as soon as i started recording some of the PIDs stopped working and a few of the tables went weird?? I will get the Wideband O2 Sensor for it. I was hoping there was a list of a sort of which maps to log and which PIDs i actually need to monitor. I will start skimming the Forums again until i come across something
    Mar 2009
    Killing the TM, PE delay, and some of the other nannies is a great place to start. Shorten shift times and bring the timing in sooner makes a difference as well. If you have overheating issues, get a bigger radiator. What they put in those trucks was pathetic.
    Mar 2020
    Thanks Supercharged111 i appreciate the feedback! I will start messing with those settings. As for the overheating i did install a dual electric fan with smart control to self adjust depending on different scenarios. I also re routed the oil lines to skip the radiator and go to a auxiliary cooler with dual fans and i re routed the transmission oil lines to skip the radiator and go to a auxiliary cooler with dual fans. that helped a ton! I don't have the overheating issues as much now but i don't want the truck to work so hard. Usually when i tow its up hill and of course my truck at 50mph up hill it cant make up its mind which gear it wants to stay in. Basically i want some low end torque to get off the line a little easier and change shift points and PE for the uphill battles.
    Jul 2003
    if you want to be able to tow and not think about it leave it stock. If there might be any advantage it could be in Trans calibration. Then again you also should have a tow mode for it. Leave it stock.
    Mar 2009
    Great idea. That 60 second PE delay is super helpful when pulling uphill.
    Jul 2003
    with 87octane... yes it is...
    Mar 2009
    Go on.
    Jul 2003
    So GM Made a mistake?
  1. 4L65E tuning and towing
    By truethinker in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 19th, 2011, 01:19 PM
  2. 2004 2500HD 6.0ltr towing tune ?'s
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: September 18th, 2009, 01:33 AM
  3. towing
    By juster12 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: August 19th, 2009, 08:13 PM
  4. Towing tune
    By Gordy M in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 8th, 2007, 10:25 AM
  5. 2005 avalanch tune for towing
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: May 29th, 2007, 03:41 PM
