Results 1 to 8 of 8
Thread: B0101 Main VE Table not Found
    Mar 2020
    Default B0101 Main VE Table not Found
    I am new to EFILive and have spent the last week and a half reading lots of forums and just trying to generally familiarize myself with the software and tuning theories. One thing I've seen mentioned a few times now that I can't seem to fine is B0101 Main VE Table. I have scanned a tune onto my laptop off my 2009 chevy silverado with the E38 ECU and when I have that tune open in Tune 7.5 I can't seem to find B0101. Is that not the main VE table people look at and and mess with while tuning?
    -Nick
    Mar 2009
    VE in the GenIV stuff consists of a bunch of 2D tables. Do a search for virtual VE, that has an interface like the GenIII stuff and EFILive does all the work for you.
    Jul 2003
    B8101
    Mar 2020
    Thank you Supercharged111 and Highlander!
    Mar 2020
    I have now found the virtual ve tables and played with them some. I did some data logs today and tried adding some fuel to the truck through the ve table. A couple questions I came up with while messing around today are:
    1. Do you have to reset the target that the factory o2 sensors are trying to hold if you change the air fuel ratio? I noticed with my truck, it runs very close to 14.7:1 AFR until you get up around 60-65% throttle then I changes to 13:1 and holds it to WOT. Does that mean you want to change the o2 sensors target air fuel ratio for a given throttle percentage?
    2. I noticed that when at WOT my throttle was only registering as open 82%. Is that normal and is that something that people normally change?
    Still getting this stuff figured out but starting to get a better understanding of it as time goes on. Any info will be greatly appreciated!
    -Nick
    Feb 2006
    I wrote this up a few years ago, this might help get an understanding..GM-Late-Model.pdf
    Thanks Tre-Cool.
    Mar 2020
    Tre-Cool your write up helped a lot! Thank you!
  1. B0101 VE table display units
    By Illegal Vette in forum Gen III V8 Specific
    Last Post: April 7th, 2016, 11:57 PM
  2. Adjusting Main VE Table, When and By How Much?
    By n8dogg in forum Gen III V8 Specific
    Last Post: June 15th, 2011, 06:40 AM
  3. main VE table
    By 1sikmax in forum E37, E38 & E67 PFI ECM's
    Last Post: May 26th, 2009, 04:36 AM
  4. Use of Main VE Table
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2005, 03:05 PM
  5. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
