Results 1 to 3 of 3
Thread: LBZ Winter elevated idle
    Default LBZ Winter elevated idle
    It would be nice if EFILive had found the tables for the cold weather elevated idle in the LBZ, but since those seem to remain unavailable, does anyone have a cax file that would allow one to adjust the elevated idle parameters?
    Sent from my 2PZC5 using Tapatalk
    Member koolky's Avatar
    Aug 2013
    I've had this mapped for a a while but never tried it. Use at your own risk. OS 12632483 / 512632483.
    Code:
    [1E25A8]
    ;	Description
    DESC.001 =	Not confirmed
    DESC.002 =
    DESC.003 =
    DESC.004 =
    DESC.005 =
    DESC.006 =
    DESC.007 =
    DESC.008 =
    DESC.009 =
    DESC.010 =
    ;	Seg	Caption	Major	Minor	Vis	Dis	2D	Grp
    VIEW =	2	"Elevated Idle RPM"	"Idle"	""	1	2	0	0
    ;	Address(es)				BitOff	Bits	Typ	Inv
    ADDR =	"1E25A8"				0	16	SNM	0
    ;	Units	Factor	Offset	Prec	MinLimit	MaxLimit	MinUser	MaxUser
    SI_SLOT  =	RPM	1	0	0	0	2500	0	2500
    ;	Body	Col	Row
    ULABELS =	.	.	.
    ;	Enumerations
    SI_ENUM =	.
    IM_ENUM =	.
    ;	Units	Labels
    SI_COL =	.	""
    IM_COL =	.	""
    SI_ROW =	ECT	"-45,-40,-30,50,63,68,70,96,97,98,99,100"
    IM_ROW =	ECT	"-45,-40,-30,50,63,68,70,96,97,98,99,100"
    Aug 2013
    OS 6128 address: 1E24E8
    Let me know if you have any luck. This table is just above B0701. Auto, manual and Kodiak's all have different values.
  1. Elevated Idle
    By WisconsinHick1 in forum Cummins 5.9L
    Last Post: March 8th, 2016, 05:42 PM
  2. Tuning LBZ Elevated Idle
    By Philbilly2 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 5th, 2016, 06:40 AM
  3. Elevated Idle Missing
    By rdaniels in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 7th, 2009, 11:30 AM
