Results 1 to 4 of 4
Thread: 2012 Ram will not license, gives $0549 error
    Feb 2007
    Default 2012 Ram will not license, gives $0549 error
    I'm trying to program a truck, and it keeps giving me the same error. The truck cranks and runs, but I can't even get past the licensing part of the flash. As it is running through the procedure, it halts after the verification section. I tried to just skip it and flash the truck which seemed to be working (it pulled the ECM serial number and verified that), but it told me the controller needed to be licensed. I'm at a loss here. I searched, but all the threads I'm seeing with this error are guys who flashed and then had the error pop up.
    Not sure what software / firmware you are running there but there is no known issues with the current September 2019 beta if you wanted to update to that.
    https://forum.efilive.com/showthread...lease-Update-2
    Feb 2007
    Thanks for the response, but I actually found the problem after I posted the thread. The truck has an aftermarket radio in it, and I guess it has some sort of data display function or some other reason it needs to be tied into the data wires because someone spliced them into the diagnostic can wires in the obd2 port. Once I disconnected them, all was good.
    Pretty typical cause of issues actually, the old LB7 & LLY's were notorious for this with after market stuff connected to the communications bus.
  1. 2012 Ram ECU BIN file
    By piciu82 in forum Cummins 6.7L
    Last Post: November 13th, 2018, 03:34 AM
  2. 2012 Dodge ram 1500 with 5.7 Hemi
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2016, 08:18 AM
  3. 2012 ram cab and chassis issues,
    By viper91180 in forum Cummins 6.7L
    Last Post: April 27th, 2016, 12:14 PM
  4. 2012 Ram stock tune
    By turk88 in forum Cummins 6.7L
    Last Post: April 16th, 2015, 03:03 PM
