Results 1 to 8 of 8
Thread: Emissions intact tuning help!
    Aug 2019
    Default Emissions intact tuning help!
    Looking for any advice on doing some emissions intact tuning on my 2011 Ram. Any advice would help. How not to completely plug the DPF and such. Thanks everyone.
    Lifetime Member Road's Avatar
    Feb 2015
    Quote Originally Posted by Twistedshafts View Post
    1st thing I do is raise torque limiters. Just doing that is good for 40-50hp. Smooth out the pedal map and make it more linear. Might even mess with torque to fuel maps. These will keep it using factory fueling and minimize damage to the dpf. My testing shows anymore fuel will degrade the dpf quickly. Keep a watch on fuel mileage and focus on improving it while doing changes.
    Aug 2019
    Awesome, thank you. If I increase timing will I need to adjust my post or pilot timing to work with added main timing?
    Feb 2015
    No sir
    Aug 2019
    Thank you, appriciate the advice very much.
    Jan 2016
    Quote Originally Posted by Road View Post
    No sir
    Road, is this because the timing values in post/pilot are the actual value before/after the main injection?
    Feb 2015
    Quote Originally Posted by TWITCH02X View Post
    Correct
    Jan 2016
    Correct
    From what ive read "SOI" for Pilot timing is the amount of degrees before "SOI" for the main event, but what about "SOI" for post??
    Are the post timing numbers based off the "end" of injection on the main event???
  1. 2010 Emissions Compliant EFI Tuning
    By Dinner in forum Cummins 6.7L
    Last Post: May 7th, 2018, 04:04 AM
  2. S87 recall and emissions present tuning
    By Quint in forum Cummins 6.7L
    Last Post: July 17th, 2017, 04:44 PM
  3. EFI Live Tuning and passing emissions testing in Califoria?
    By blades11b in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 14th, 2015, 06:34 AM
  4. emissions related tuning?
    By C Murda in forum General (Diesel)
    Last Post: April 8th, 2013, 11:03 AM
  5. Replies: 1
    Last Post: April 5th, 2013, 10:25 AM
