68rfe
Tips for making the 68 live longer through good tuning techniques?
change the cals to keep the LR sprag engaged through second gear
Thank you. Do you know by chance how to record output shaft speed rpm. I have the pid enabled in V8 but it does not record. Need it to adjust shift points.
Is your tune file upgraded to a CSP4 file?
I rarely use EFILive for data. I typical use a scanner (SnapOn Solus Edge) to watch whats going on.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
