Results 1 to 4 of 4
Thread: Upgradeable OS
    Aug 2019
    Default 68rfe
    Tips for making the 68 live longer through good tuning techniques?
    Oct 2012
    change the cals to keep the LR sprag engaged through second gear
    Aug 2019
    Thank you. Do you know by chance how to record output shaft speed rpm. I have the pid enabled in V8 but it does not record. Need it to adjust shift points.
    Oct 2012
    Is your tune file upgraded to a CSP4 file?
    I rarely use EFILive for data. I typical use a scanner (SnapOn Solus Edge) to watch whats going on.
