Results 1 to 3 of 3
Thread: Cmd cm2200 pids
    Aug 2019
    Default Cmd cm2200 pids
    In my data logging I cant select transmission PIDs. I have gone through all the groups under my ecm with auto trans selected and none of them allow me to select trans PIDS. I know I must be missing something because I need to monitor trans line pressure, output speed, gear select, and TCC. Looking for direction in how to get those pics to work pleas.
    You should see on the right all the different PIDs related to the transmission.
Name:	CMD Trans PIDs.png
    Aug 2019
    I did that but under v7.5 scan tool it wont show those PIDs under my controller. It will show them under the dashboard in V8 but the problem I have with V8 is I hit the red record button. It starts to record then just stops.
  1. how do i get CMD CM 2200 on my v2 its not in my list of pcms
    By CTB performance in forum Cummins 6.7L
    Last Post: June 8th, 2018, 12:56 PM
  2. CMD AF/EQ Ratio
    By Road in forum Cummins 6.7L
    Last Post: October 8th, 2017, 10:48 AM
  3. CAX and CMD, CME
    By Red66 in forum Cummins 6.7L
    Last Post: July 13th, 2017, 05:53 AM
  4. Trans Press Cmd vs Actual
    By dsltnr in forum Cummins 5.9L
    Last Post: July 14th, 2012, 12:07 AM
