okay im new to this so ill see if i can change that. Is Private messaging done via email? I could possible try and pm you
Private message is just messaging here on the forum.
its different from Email.
Try to PM me and see what happens.
Is this the injector part number from Deatschwerks?
18U-01-0060-8
I dont see the anything with private messaging but should i allow vcard down load
Na i wouldnt.
Go to the Settings at the top right of the screen.
On the left side close to the bottom you will see General Settings.
Second section down in the center you will see "Private Messaging on" "Private Messaging off" with a radio button beside one of them.
Does your screen look like this?
i still see no pm options even when i look at your profile
yup with out the private messaging stuff
35U-01-0060-8 was the injectors
Oh well.
Whats your email.
I can help you get it sorted out. Ill be on my phone tho so email works best.
I been looking over the tune and wondering why command the PE 12.16 in B3647 and 12.06 in B3618?
Injectors look way off if your Fuel Pressure is ~58psi and they are the Deatschwerks 60#.
and the airflow is reading extremely high at such low Rpm/boost.
its 43.5 pounds of rail pressure
email is in-ksd-fo@outlook.com
