Results 11 to 20 of 25
Thread: Questions AutoVE Tuning my first turboed engine custom os #3 LS1B
    Apr 2020
    okay im new to this so ill see if i can change that. Is Private messaging done via email? I could possible try and pm you
    Private message is just messaging here on the forum.
    its different from Email.
    Try to PM me and see what happens.
    Is this the injector part number from Deatschwerks?
    18U-01-0060-8
    Apr 2020
    I dont see the anything with private messaging but should i allow vcard down load
    Na i wouldnt.
    Go to the Settings at the top right of the screen.
    On the left side close to the bottom you will see General Settings.
    Second section down in the center you will see "Private Messaging on" "Private Messaging off" with a radio button beside one of them.
    Does your screen look like this?
ID:	23257   Click image for larger version.
    Apr 2020
    i still see no pm options even when i look at your profile
    Apr 2020
    yup with out the private messaging stuff
    Apr 2020
    35U-01-0060-8 was the injectors
  9. #19
    Oh well.
    Whats your email.
    I can help you get it sorted out. Ill be on my phone tho so email works best.
    I been looking over the tune and wondering why command the PE 12.16 in B3647 and 12.06 in B3618?
    Injectors look way off if your Fuel Pressure is ~58psi and they are the Deatschwerks 60#.
    and the airflow is reading extremely high at such low Rpm/boost.
  10. #20
    Apr 2020
    its 43.5 pounds of rail pressure
    email is in-ksd-fo@outlook.com
  1. 2 Quick Questions: LS1B Tuning
    By truethinker in forum Petrol / Gas
    Last Post: August 19th, 2015, 10:50 AM
  2. Custom os tuning questions
    By cyipher in forum Custom Operating Systems
    Last Post: May 9th, 2013, 09:33 AM
  3. Two Engine Swap Questions (less tuning than converting, really)
    By Admiral Ballsy in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2011, 06:38 PM
  4. Engine Trans Dyno Tuning Questions!
    By TBMSport in forum General (Petrol, Gas, Ethanol)
    Last Post: November 14th, 2009, 11:37 AM
  5. AutoVE Tuning a Boosted Custom OS Z06
    By TaTommy888 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 27th, 2005, 07:32 AM
