Results 1 to 2 of 2
Thread: Enabling Flex Fuel in 2004 GTO OS
    May 2015
    Default Enabling Flex Fuel in 2004 GTO OS
    I live in Colorado where there is abundant E85 and if I want to use it I have to use the 2006 or 2007 van OS so that my fuel composition sensor is enabled. Colorado also has a stringent emissions program and my car is configured for their purposes as a 2004 GTO. It's really an 82 Corvette with a built Gen 3 LS motor, but I have to use the 2004 GTO OS 12587604 when I get emissions tests or technical inspections. I like this OS, it starts a little easier with it and it would be really nice if I could run it all the time and still have flex fuel capability. I have an HP Tuners file for a 2004 GTO that supposedly has had a segment swap which enables flex fuel and the sensor but that doesn't help me, so the question is: Do any of you know how it could be enabled or segment swapped with the GTO OS in EFIlive?
    May 2015
    I see that this has come up in the past without a solution, so I'll modify my question to this: Is it possible for a programmer to modify or copy the code from a FF OS to enable it in the GTO OS?
  1. 2004 GTO + Flex Fuel Sensor
    By recrit in forum Gen III V8 Specific
    Last Post: March 22nd, 2020, 09:13 AM
  2. 2004 GTO tune help
    By Beendmax in forum Gen III V8 Specific
    Last Post: July 23rd, 2015, 07:58 AM
  3. 2004 auto 5.7 GTO
    By justafarmtruck in forum Gen III V8 Specific
    Last Post: February 8th, 2012, 11:49 AM
  4. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 05:15 AM
  5. Problems with 2004 GTO
    By S10Wildside in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2006, 10:31 PM
