I have been tuning for about a week using the Roadrunner PCM and have been getting the hang of it, with the tune improving each day. I have had a problem that when the cooling fan kicks in while idling, the engine dies. I have tried heaps of things including B4301, Desired air, richening up idle, but it still stalls. I turn the a/c on and there is no problem.
Yesterday while driving home the car started surging badly and the check engine light came on. I pulled over and the engine died. I restarted and all seemed OK. I checked the DTC's and found Cam position sensor circut high, cam position sensor circuit low, and Theft deterrent learn mode. I hoped it was just a gremlin.
Today while driving home as I pulled away from a traffic light the car started surging again, but no check engine light. It was so bad I had to stop. The car would idle OK but as soon as any load was applied it would buck like crazy. I turned it off and tried again but same thing. I flashed back in my last tune and it bucked a bit for a second but then was OK and I got going and got home.
I checked the logs and the injectors where being shut off, like a rev limiter! Attached is a screen grab of the log.
Also attached is a pic of the log where the fan starts and the car stalls. When I restart some strange things happen.
My car is a VY Commodore with 222/224 112lsa cam. The tune is based on a 2004 VY GTS with custom os1.
Can someone tell me what is going on?
