Results 1 to 3 of 3
Thread: 2006 5.9l fire punk efi live stuck on 4th gear
    Apr 2020
    Default 2006 5.9l fire punk efi live stuck on 4th gear
    So I have a 2006 ram 3500 5.9l cummins. Truck prior to the efi live had a H&S tune on it. They told me I can just re write over that program with the efi live from fire punk. So I followed instructions it came with, pit ignition on run position then load full program tune and accept license,turn off ignition, then I cranked the truck up and went to go drive it but noticed it was stuck on 4th gear. What can be happening?
    Oct 2012
    Did you return the truck to stock with the H&S prior to flashing in the tunes from FirePunk?
    Dec 2017
    What makes you think the truck is stuck in OD? Does it shift up through the gears and not want to downshift? Is the transmission stock or built, hows fluid look, when’s the last time you dropped the pan? Shouldn’t matter if you returned truck to stock with the hs since the file was written over, that would just effect resale of the hs since it’s still vin locked to your truck
  1. Replies: 3
    Last Post: November 14th, 2012, 06:31 AM
  2. Need to hold 4th gear for dyno
    By samdweezel05 in forum Allison 5 & 6 Speed
    Last Post: July 1st, 2011, 01:54 PM
  3. C6 w/ A6 stuck in 4th after ECM flash only?
    By DVR IMP in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 22nd, 2011, 10:38 AM
  4. will EFI Live V1 work on a 2006 Impala SS?
    By mtomac in forum Gen IV V8 Specific
    Last Post: September 12th, 2010, 12:57 PM
  5. Keep TCC locked in 4th gear
    By FnGone in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 24th, 2008, 11:02 AM
