Results 1 to 10 of 10
Thread: Engine LLT Stand Alone
    May 2020
    Default Engine LLT Stand Alone
    Hello ! My name is Mauricio, and i'm from brazil.
    I have a LLT Engine, that cames from a Holden Commodore, and i'm trying to use this engine in a project, with manual transmission. So I need to make it works stand alone.
    So i bought in USA an E69 ECM, reprogrammed, but they couldn't remove VATS. SO i was looking, and saw that Chevrolet Transverse uses the same engine, but with E39 ECM.
    Is it possible, uses E39 ECM on my project ?? E39 Vats can be removed.
    Thank you !!
    Mauricio, I am not sure if the E39 can be used instead of the E69 on that engine (someone else might know). But you can certainly disable the VATS on the E39 ECM if that ECM can be used.
    I'm surprised someone out there can't turn off the VATS for you, maybe someone in Europe where the Bosch ECM's are very popular with tuners.
    May 2020
    Hello GMPX !! Thanks for your answer...here in brazil, this engines are uncommon, everything is more difficult here...
    But I hope to get good news here.
    Thank you!!
    EFILive doesnt support E69s for tuning or VATS deletes, you can only read and write them. There is no tuning support.
    Erik, Mauricio said that he got the ECM reprogrammed in the USA but the tuner couldn't remove the VATS, it might not have even been an EFILive tuner that supplied it.
    I think the question is now that it appears nobody is able to disable the VATS on the E69, can the E39 with a harness change etc be used instead on the LLT as it is.
    Jan 2017
    GMPX, could you PM me pls
    Ah gotcha Paul, I glossed over that! I looked around a bit and see a few shops mentioning E69 and VATS deletes, but not sure if they're successful or not.
    For an E39 swap from an E69, I'm guessing you'd need to look at every aspect of it as I can't find anyone who's mentioned it either. I see the LLT was used on 2013-2016 Chevy Traverse' (instead of the LFX) and use the E39A. I'm not that familiar with these ECMs, but you could look at doing an E39A swap and it'll likely be straightforward. As long as the crank/cam/VVT signals are compatible, swapping throttle bodies or sensors would be a simple task if needed.
    Quote Originally Posted by bjmauricio View Post
    Thank you !!
    Mauricio, contact these guys as they can do VATS deletes on the E69 ECM - https://www.trifectaperformance.com/
    May 2020
    Hello, i contacted them, but it is U$ 498 only to remove VATS...i think it's so expensive.
    I guess, changing the ECM to E39, will be better. But first, i need to be sure, that it's possible.
    Well you will need to get an E39 wiring harness (not sure how much that might cost) and then spend hours changing it, expense versus time is the problem you have.
  1. Can't get engine to start on stand...
    By Jayyk31 in forum Gen III V8 Specific
    Last Post: March 10th, 2017, 05:26 AM
  2. '08 LLT controlled by new ECM?
    By jpndave in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: September 4th, 2012, 09:41 AM
  3. e38 stand alone
    By proflash in forum E37, E38 & E67 PFI ECM's
    Last Post: November 10th, 2009, 03:57 PM
  4. Stand alone flash
    By bdr2008 in forum FlashScan V2
    Last Post: May 7th, 2009, 02:57 AM
  5. Stand Alone Yet?
    By vandykeben in forum FlashScan V2
    Last Post: June 12th, 2007, 03:43 AM
