Results 1 to 1 of 1
Thread: Scan tool DVT procedure for VATS relearn
    New Member Turbosaurus's Avatar
    May 2015
    Default Scan tool DVT procedure for VATS relearn
    Does anyone know the correct procedure for using the theft relearn feature of V7.5 scan tool DVT on an E38 ECM? I've been trying the cycle method of relearn (3 cycles/600 seconds “start-on”), and while I can get the “Service Theft Deterrent System” DIC message to clear and the security indicator lamp to go out, it still will not crank. When the Deactivate is selected on the DVT function, the “Service Theft Deterrent System” immediately shows on DIC along with security indicator lamp. Acts like it wants to work, but won't stick. Any documentation and/or tribal knowledge out there?
  1. Anti Theft Relearn using Scan DVT on E38
    By Turbosaurus in forum E37, E38 & E67 PFI ECM's
    Last Post: May 6th, 2020, 01:10 AM
  2. Scan Tool DVT ECM Setup CASE
    By hapnermw in forum General
    Last Post: September 7th, 2013, 08:56 PM
  3. DVT Idle Relearn
    By Protec in forum E37, E38 & E67 PFI ECM's
    Last Post: October 19th, 2012, 04:25 AM
  4. Replies: 19
    Last Post: May 18th, 2011, 12:38 AM
  5. ECM relearn procedure and VIN
    By killerbee in forum Duramax LLY
    Last Post: December 13th, 2009, 12:03 PM
